124A/ B interstage Hammond xfmrs
Has anyone tried those in any radio using pushpull interstage which needs 4:1 ratio? These have 3:1.
I wonder if it resuls in some loss of power. Also size is smaller.
Had using it result in any negative effects?
Radios like 20, 111, possibly 95, 87.
I used 124E in my sparton 1466 worked as good as the original.
Mike, upon recommendation I too used a 124E on my Fada with P-P 45s. Worked dandy.
Jerry
I too consider them as the modern 'go to' option.
OK ood to know, it too is 1:3 turn ratio (1:9) impedance.
Q1: Is there real advantage over A and B otions? "A" is 27 bucks vs "E" being 45 bucks.
Q2: is there some loss of power due to 1/4 of driving voltage loss? Or does it matter conidering it is a radio?
Q1 for a am radio I doubt you would notice the difference.
Q2 If the radio has a lot of audio gain probably won't notice it if it doesn't it may lack volume on weak stations.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5481 online users. [Complete List]
» 1 Member(s) | 5480 Guest(s)
