need help with model 48-1262
I could use some help with the turntable. The radio works perfectly. The motor on the turntable works and is up to speed. The auto feeder works as well. The problem is sound. I need to know the order that I should go thru to check the needle, pickup, etc. Please help. Tom
Hi Tom
At first glance, I would suspect a faulty phono cartridge.
Before proceeding, however, I suggest you peruse this thread:
http://www.philcoradio.com/phorum/showth...hp?tid=947
Phorum member Harlan gave some very good advice on this subject.
Good luck...and keep us posted.
Thank You, I will give that a try tomorrow. I will keep you posted. Tom
There are currently 6689 online users. [Complete List]
» 2 Member(s) | 6687 Guest(s)
