Need chassis model 46-1209 or tuning cap part # 31-2719R
I have a set with a frozen tuning cap, and need a replacement.
This is for a Phiilco chassis 46-1209. I need either a whole
chassis with a freely moving tuning cap, or just a scavenged cap.
Can anyone help? If this is the wrong part of the forum to use,
then I'll be glad to repost in want ads or wherever.
yram, no chance to loosen up tuner? PL
That was already tried mechanically, and the part frozen was the actual
cap, not the reduction mechanism, which was badly damaged. I need a
new cap, or I'm going to have to rebuild the reduction. The pinion
gear (brass) has damaged teeth, and the driven gear and tensioner
now are missing a couple of teeth. I can easily reverse the pinion gear
and use the other end, likely, but the driven gear and tensioner
are likely goners.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6442 online users. [Complete List]
» 1 Member(s) | 6441 Guest(s)
