37-116 vs. 38-116 performance?
I was looking over the schematics of both models and noticed that the front end was significantly simplified on the later 38-116 code 125. Most of the short wave band trimmer adjustments were eliminated.
Where each band on the 37-116 had individual adjustments for dial calibration and tracking at both the low and high freq ends of each band, some SW bands on the 38-116 have no antenna or RF trimmer adjustments at all. So, at least on paper the 37-116 front end looks far superior with the ability to optimize dial calibration and sensitivity on all bands.
The 38-116 (125) front end looks like an attempt at cost cutting, both in parts and labor to align. What makes it more puzzling is that they also chose to use this simplified design for the top of the line 38-690.
Does anyone have experience using both models who can comment on how the short wave dial calibration and sensitivity compares between the models? I was considering getting a 38-116, but after seeing the RF section schematic, I am a bit disappointed by the changes from the earlier model.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5481 online users. [Complete List]
» 1 Member(s) | 5480 Guest(s)
