Philco 42-400 With Add On Fm Adapter
today I was asked to look at an old radio the Elk's Lodge here in town had that come out of their rental property. Initially I thought it was a repro since they said it was AM/FM. But then he said it had tubes, so I had to go look.
Turns out it is a Philco 42-400 that one of the local radio shops installed an add on FM unit to in 1951. The date was written in pencil on the chassis. The tube adapter was installed on one of the 6F6G tube sockets and grounded onto the chassis. The shielded cable was plugged into the chassis. I am assuming it must have worked, but have never heard of this type of setup before.
This could be great as I have a 42-400 with a cabinet that is in pretty nice shape. This one was in a damp area and has a lot of delamination as well as some missing veneer and glue joints coming apart.
[Image: http://i1185.photobucket.com/albums/z345...2aaf9d.jpg]
[Image: http://i1185.photobucket.com/albums/z345...d9c15d.jpg]
[Image: http://i1185.photobucket.com/albums/z345...6e0e9e.jpg]
[Image: http://i1185.photobucket.com/albums/z345...0b04d8.jpg]
[Image: http://i1185.photobucket.com/albums/z345...077bc7.jpg]
Gene
Looks like the Hallicrafters FM converter to convert the pre-war FM band to the modern FM band.
[Image: http://www.somerset.net/arm/radio_pictur...erters.jpg]
[Image: http://userpages.bright.net/~geary/fm/mfgfmconv.jpg]
Sean
WØKPX
Neat that it tunes from 84 thru 111 Mc.
A very cool discovery!!! Icon_thumbupIcon_thumbup
I could use that one when I fix my Spinet.
Wow, that was quick! Thanks for posting the pics of the unit. I learned something new today. Would never have thought about Hallicrafters. I have seen the Pilotuner and the Meissner (I have one of those).
I think I will try to get it into my 42-400, without punching a hole in the cabinet. I'll just have the knob facing out the back of the set.
NEATO!
Gene
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5474 online users. [Complete List]
» 1 Member(s) | 5473 Guest(s)
