Philco 112 Lowboy restoration (caution, lots of images)
Thanks for posting this thread. I just got a Model 112 Lowboy today for $100, but with a badly water-damaged top. It is almost certain that I will have to replace the top veneer.
[Image: http://i269.photobucket.com/albums/jj77/...0found.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
There are several threads here on similar radios. One is mine on 111 which uses the same chassis.
My problem was: every single transformer other than the power one was open.
