DeWald J-802 Schematic
Does anyone know where I can get a schematic for this DeWald? It is not an 802 and not a J-800.
The tube line-up is:35L6GT,12AL5,12AU6,12BA6,12BA6,12AT7,12AV6.
Thanks
Eric
The Villages, FL
Does this set use a selenium rectifier? Assuming that the tube lineup is correct? I'm guessing that it's a transformerless AM/FM set ( I do not want to say AC/DC in case they used a doubler).
That's the one Arran! Do you know where I can get a schematic?
Eric
The Villages, FL
If it is built after 1946 it maybe in Sam's Photofacts. Don't have my index handy.
I have some Beitmans books, I will check in those when I get a chance, it looks familiar so I may have seen it whilst flicking through one of them.
Thanks Arran.
Eric
The Villages, FL
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
