Was working, now trying to burn up!
#31
Ben, can you post a picture of the bottom of the chassis? There seems to be some confusion as to whether the radio has been recapped or not. Showing a picture of the components under the chassis will settle the question.
In the photos you have already posted, the caps visible have been all modern orange drop style replacements, so this confirms that at least some have the caps have been already changed.
#32
Oh, I'm sorry. I thought I did post the underside shot in this thread. I did in my introductory one but not here too like I thought I did.
Here it is:
[Image: http://img.photobucket.com/albums/v222/i...ny1168.jpg]
#33
With due respect.. Perfunctory means done as part of a routine or duty.
#34
ben I only see 2 lytic`s should be 8-12-16 3 of them
#35
Quote:ben I only see 2 lytic`s should be 8-12-16 3 of them
I am a complete noob... I don't know what you are talking about.
EDIT: You need to go easy on the slang. Icon_lol I managed to figured out you meant "Electrolytic capacitor". There *ARE* three... unless I am sorely confused. There is a large yellow one, a grey one next to the yellow one and a smaller black and grey one to the upper left in the pic between two tubes base connectors.
#36
ben
see 2 blue caps with arrows they are electrolytic`s should be 3 of them according to schematic an 8mfd,12mfd,16mfd part 21
#37
The large yellow capacitor is this: Sprague TVA1706
It's installed in such a way that it's writing is facing the chassis body. However, I can just barely make it out. So yes, it has 3 capacitors.
They are 10, 12 and 22. They are higher than spec'd but as I understand things, that's generally ok. (Edit: or not...?) Having too small would be a problem.
#38
Ben,
Two possible issues:
1) We can't see for sure from the picture, but that yellow cap should have been disconnected if new ones were installed. Also, if only two of the three caps were replaced and one of the originals was kept (which appears to be the case), that one original section within the yellow multi-section cap is highly suspect and should be replaced.
2) Do you have any idea how long ago those 'new' electrolytics were installed? If you don't know the answer to that question with certainty, then you really should replace the 'new' ones as well. If an electrolytic has been sitting, unpowered for 10, or 20 years, or possibly even longer, then they are quite likely bad as well. I don't say this to cause you unneeded work or expense, it is just the reality of electrolytic caps.
Good luck.
Jon
#39
The yellow cap is part of the restoration someone did. It's not a paper cap. They used 3 modern caps to take the place of the original metal casing multisection electrolytic cap. The three that were already pointed out.
I think you are seriously confused about what you are seeing in the photo. Why on earth are you referring to a Sprague TVA1706 as a "multisection" capacitor? It's not. I already provided a link to the technical information about it. You are also acting like it's an original, 73 year old capacitor.
Maybe some better photos will help clarify things for you. Please referred to attached photos.
On a separate note -- Over in my thread about the record player restoration thread, I discovered that the bakelite block cap has NOT been restored. It contains two small 0.01uF capacitors encased in tar. I will be digging out the old ones and putting in new ones.
Here's a nice "how to" on those bakelite blocks if you are interested.
#41
klondike98 - Thanks for the link. I will be using a hair dryer instead of a heat gun. Icon_lol
#42
That's what I use and it works fine.
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
