Light socket repair
Any one out there that has rewired the dial light sockets on the automatic tuning sets? I have one with a couple bad wires that need replacing and thought I'd ask before taking one apart.
Looks like the socket that lights the dial/band indicator needs it as well.
I don't believe this is quite what you're asking about but Ron did a pilot lamp rewire in the tech section, maybe part if it will help...
Thank you Bob that did help Icon_smile
The rewiring went perfectly thanks to the pilot lamp rewire by Ron. The hardest thing was finding the correct plastic washers locally.
Icon_thumbup
I found a source for the #6 plastic/ nylon washers, ACE Hardware has them.They are 0.11 apiece.They are in the pullout
trays in the single nut/bolt and washer section.
(01-02-2015, 11:17 PM)doug-5er Wrote:  I found a source for the #6 plastic/ nylon washers, ACE Hardware has them.They are 0.11 apiece.They are in the pullout
That's great! I have an Ace Hardware close by. Lowe's only had 5 of them and they were much more. I was waiting for them to get a new shipment in.
There are currently 3278 online users. [Complete List]
» 1 Member(s) | 3277 Guest(s)
