Alignment info for all Philco models in two volumes
Hi Everybody,
Many may already know about this, but I just came across it.  This link
http://www.tuberadio.it/docs.htm
has a lot of useful information in general, but the top left links caught my eye.  This would be helpful in cases where the schematic/alignment info on NA is blurry or non-existent.  I can't verify the claim to it having information for "all" Philco receivers, but heck, it said so on the internet so it must be true, right? Icon_lol
 I have one of those, it's a John F Rider book, but I think mine ends at 1937 or so, I will double check.
There are currently 9572 online users. [Complete List]
» 3 Member(s) | 9569 Guest(s)
