Philco 16b found dead
      Saved another,  heres how I got, rebuilt the cabinet ,next post will show it  refinished, then in electrical section will show the guts/before and after
Wow, great job resurrecting that cabinet!
Hympty Dumpty?
There are currently 9746 online users. [Complete List]
» 1 Member(s) | 9745 Guest(s)
