New project today
Opened the back of the truck today and found an RCA model 281 hiding back there.
Now how did that get in there?
Guess  I'll just have to bring it in, but it weighs 174 lbs.
Should look nice parked along side my model 280.
What a beast.
murf
OK murf we're expecting pics now Icon_biggrin
Better you than me!!!
(03-22-2015, 08:15 PM)murf Wrote:  Opened the back of the truck today and found an RCA model 281 hiding back there.
What a beast.
murf
  Does it look like this
Should be a good radio as long as the input transformers are ok. I have had a few RCA's from this era and they all seemed to have at least one bad input transformer and at least one model used an odd one that had six wires coming out of it.
Thats the one Fred.
Looks like a challenging chassis
murf
Beautiful set.
My back starting acting up for no reason since yesterday morning.
Now I know why - BECAUSE I LOOK AT THESE MONSTROUS RADIOS OF YOURS TOO MUCH !!!
Icon_mrgreen Icon_twisted
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3991 online users. [Complete List]
» 1 Member(s) | 3990 Guest(s)
