Philco 42-1012 Antenna ??
ALL, Looking at the schematic part 1A is where the FM antenna is hooked to on Pins 1 & 2. Lookls like pins 3 and 4 are not hooked to anything.. Should they be? or maybe shorted? Why would there be wires to the part if they weren't to be used? Please see schematic.. Part 5 is the Brdcat Aerial Transformer
[Image: http://i292.photobucket.com/albums/mm38/...uqfz7x.jpg]
Thanks
Skip...
Schematic and notes here!
http://www.nostalgiaair.org/PagesByModel...013494.pdf
Seems like the built in dipole for FM is ion 1 and 2. For external dipole connect to these pins. Pins 3 and 4 are for external AM/SW long wire (3) and ground (4). At least that what the notes say.
Thanks, I should of read the manual more carefully. That answers my question.. Thanks again
You may close this
SKip...
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
