Identify Radio
Just purchased a Philco 6 tube radio not sure of the Model
number but it could be M-936-124 Its about a 57 thru 59 model .it uses the
small tubes..50c5,12bag,12bag,12avg,12beg and 17c9 Its a long wooded
case that sits on two plastic runners as legs with twin speakers, have a picture but not sure how to up load...tanks for any help
The "M" desginates it as probably a 1964 vintage set - especially with those miniature tubes.
Some of your tube types do not seem right? 12BE6, 12BA6, 12AV6 sound more correct to me.
The 124 signifies a CODE 124 version.
Others may be able to add more info.
