chassis model ?
hey guy`s
got a chassis for parts  seller had no clue as to what model it is
looks like 37-9 ?
dial # 27-5271
tubes are
6f6  x 2
6q7
5y4
6k7
6a8
6n7
6h6
[Image: http://i1303.photobucket.com/albums/ag14...lz5cl7.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...dfqo4a.jpg]
 what says you ?
sam
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
