Zenith 10s130 restore
Again, that Zenith looks absolutely spectacular!
Slave to an RCA Victor CTC-25
Thanks Dave, its on eBay if you want to buy it. Icon_wave Icon_wave Icon_wave Icon_wave Icon_wave
Pffft. I can't afford that! If I could, I'd buy it in a heartbeat! That is such a beautiful radio! I looked for the eBay listing, but it came up zero results.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
