Croydon/Halson recap
Gotten lit lately??? Heaters I mean.
I think the person who was supposed to send them forgot or finked out Icon_sad
Maybe they will come today?
Yes I got lit last night...
Me!
are these the correct ones?
Sal has them and I am ordering today.
New lower prices on diodes
1N4007 1000 volt 1 amp diodes
10 for $0.50.....25 for $1.00.....100 for $3.50
UF4007 1000 volt 1 amp Fast Recovery Diodes
10 for $1.00....25 for $2.00.....100 for $6.00
(10-12-2015, 11:39 AM)OldRestorer Wrote:  are these the correct ones?
Yep the 1N4007 are fine. Go a head and splurge buy 10. They do come in handy. What we are look to do it rectify 120v at .3 of an amp
PM me your address and I'll pop a few 1N4007's in the mail for you tomorrow, unless you have other stuff to order from Sal.
Thank you much John,
I did have an order for Sal.
Me
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
