40-180 mica capacitors
Greetings,
I have replaced the electrolytic and paper capacitors in my 40-180, but have now found that one of the 370 pf silver mica caps is shorted out. Because I have to order replacements for the two silver mica caps, I decided to replace the easy to reach mica caps as well. The problem is that the color code on all these caps does not seem to agree with the values given in the schematics.
For instance, parts 6 and 22 are listed as 250 mmfd, but the three colored dots are green orange green. Part 45 is listed as 110 mmfd, and it's three dots are orange yellow orange. Am I missing something in trying to determine the value of these caps? They all appear to be original components.
Tnx, Robert Hanley KA1DXR
The color dots on the old Philco mica caps don't necessarily indicate value. They are related to a part 'type'. I haven't checked recently but there's probably a chart on Chuck or Ron's website.
GL,
Bill
I had similar questions in the 40-150 I recapped and rewired last summer. I think the micas in my radio were mostly type 6 and one or two type 4 (on the band switch) as listed on Chuck's site here:
http://www.philcorepairbench.com/micacap.htm
It would be a good idea to check the production changes to see if the values were changed at any time. If not, I'd replace them with the value on the schematic.
John Honeycutt
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5641 online users. [Complete List]
» 1 Member(s) | 5640 Guest(s)
