38-12 dial lamp antenna?
Lightbulb
This is weird!
Got a 38-12 on the bench, and there is a dial lamp socket wired between the antenna coil and ground,
with red and green wire about a foot long between the socket and the set, I wouldn't even be posting this
except the wire on the socket and solder connections in the set look virgin.
anyone see an antenna connection that is a dial lamp socket?
Weird, yea!
Keith
Can't say that I ever have. Does it light up???
(11-18-2015, 12:48 PM)Radioroslyn Wrote:  Can't say that I ever have. Does it light up???
I cant imagine it does, except maybe briefly when lightening hits nearby. There was no bulb in the
socket.  I think Ill leave it on, make a screw base for an antenna and have it as a conversation piece
when I sell it.  Part of the radio's history!
Keith
Well, by the time lightning got to the little bulb, even CSI Crime Lab couldn't find it, anyone remember "Lightning Arrestors?"
There are currently 4517 online users. [Complete List]
» 2 Member(s) | 4515 Guest(s)
