Rusty chassis?
Hey Guys, next time you want to get rid of rust , try this..   https://www.youtube.com/watch?v=TlcL_vHODkc
I use electrolysis, but I also have a 100A supply.
Warren, thanks. That is amazing.
Jerry
I have just the right candidate.
[Image: http://philcoradio.com/phorum/attachment.php?aid=7969]
Yes it does have p/p 6L6's in the output.
There are currently 4287 online users. [Complete List]
» 2 Member(s) | 4285 Guest(s)
