Cap block 6287-DU used in 116B chassis question
The schematic list this as a .3/mfd block. I know it's really two .15/mfd. Now, it also list a 200/ohm wire resistor as part of the block. I didn't see anything inside it. This block had over-heated at one point, and all the tar was melted out. I'm also a little confused to which block lugs are used for the caps, vs the resistor. Can someone clear this up for me. Here's the parts listing.
http://www.philcorepairbench.com/bblokcap.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
My 650B used the same part. The bakelite block in mine looked identical to the universal type 6287-ODU. It uses two .15uf caps, one between terminals 1 and 2 and the other between terminals 1 and 3. IIRC, there was even a jumper on the outside between terminals 2 and 3.
Ed
For clarity sake, I'll number the lugs 1 2 & 3 from left to right, starting at the hold down bolt end. So, on mine there is also a jumper between 2 & 3. Just wondering if a resistor internally figures into any of this. I seem to remember talk of a resistor in one thread some time back.
-Brian
There was no resistor in mine. And yes, you have the numbering correct. The jumper is correct between terminals 2 and 3 on the outside. Icon_smile
Ed
Brian
I think you are confusing part 6287-D with 6287-DU in the listings on Chuck's site.
The two are different parts. 6287-D is not used in the 116B as it an older type, not the "universal" type with six lugs which was adopted at the beginning of the 1936 model year.
6287-DU, listed as 6287-ODU on Chuck's site (same specs, just different wax used to seal it), does indeed contain two 0.15 uF caps, connected externally in parallel to make 0.3 uF.
(Edit: Also, the 6287-DU/ODU does not contain a resistor.)
Ed has given you the correct info, also. Icon_smile
Yes, thank you gents. That's what I did. The listing confused me.
-Brian
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5638 online users. [Complete List]
» 1 Member(s) | 5637 Guest(s)
