Parts List for Philco 41-256T
Hi,
Working on a restoration of a Philco 41- 256T.
I have the schematic for the radio, I would like to
know where in the Ridders manual I can find the
parts list that corresponds with the numbers in the
circles on the schematic. For some reason Nostalgia
Air didn't have it with the schematic. It would be a
great help if I had it.
Thanks for all the help.
Tom66
