Philco 59C (1935) Toner Colors
I'm refinishing a Philco 59C like this one (not a picture of my radio):
A couple other examples are:
http://www.philcoradio.com/gallery/1935c.htm#m
http://www.tuberadioland.com/philco59C_late_main.html
It looks to me like it should have a two-tone look with the front panels lighter than the rest?
What Mohawk toner colors should I use for the front panels, main part of the front and sides/top?
I checked my notes and for mine I used Mohawk ultra classic perfect brown for all except the two small front panel sections where I used two very light coats of Mohawk ultra classic medium brown walnut. You can see the results here:
http://philcoradio.com/phorum/showthread.php?tid=9675
Yours looks great Bob! Thank you for the advice - I'll do that.
