Philco 680
#31
Bad idea for the top section as it will trap in a lot of heat. The bottom section may change some of the acoustical characteristic of the cabinet. You are better off to leave it original it being a fairly rare set.
Even though some big radios had the back, I would question the need for it.
#33
You are probally right will leave it original with no back. Thanks. Norman
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3373 online users. [Complete List]
» 3 Member(s) | 3370 Guest(s)
