Threads: 24
City: Edmonton AB CA
I picked up a nice little model 54 and I was just having a look at it and it is a run 1 radio that has never been touched. It has all of the original engraved base Philco tubes and there is not one single repair anywhere on it. Does anyone need any pictures of a pristine original Philco 54 for reference before I start work on it?
Gregb
Threads: 563
Even if no one right now needs it, makes sense for you to make as many pictures and notes as possible.
I have Kirk's chassis, not sure it is 54, could be 53 or 59, they are all similar.
Threads: 24
Yup, will do Mike. Thought I would offer if anyone was in need.
Gregb
Threads: 271
City: Wilsonville
State, Province, Country: OR
+1 on what mike said. nice clear photos of an original unit are priceless.
Threads: 214
City: Seattle
State, Province, Country: WA
I'd love to see those pictures too - and they would be a great resource for future restorers. The older these radios get the harder it is to find untouched examples.
Threads: 24
Threads: 563
Yep. very clean too!
I have on of those from Kirk. Not sure which 5x it is but very similar. The two big wire resistors are not easy to forget.
I heard they are a b**ch to work on. Too crowded.
Threads: 271
City: Wilsonville
Thanks! Thats a nice clean chassis.
Threads: 214
City: Seattle
Beautiful - thanks for the pictures!
Threads: 11
City: Bellmawr, NJ
IF,,I remember right,,,Ron R. worked on something like this,,,,were he had to change out them coil resistors,,,
Threads: 271
City: Wilsonville
I think it was this 53C thread.
Threads: 24
Well the one good thing is I know everything is good because the radio works as is.
Gregb
(This post was last modified: 05-25-2016, 10:13 PM by gregb.)
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
