Dial Cord Schematic for TH-4
I've looked everywhere for a dial cord stringing schematic for the 1939 vintage Philco bakelite case TH-4. Anyone have one available?
Hi and welcome to the Phorum,
I would suspect it's pretty simple as the pointer is attached to the tuning cap and doesn't have a sliderule dial.
http://www.theoldradiofixerupperguy.com/pdf/DS1_49.pdf
Something like #6 should fix it up..
Welcome to the Phorum!
Icon_wave
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
