Grandfather Clock Finial
I'm the proud owner of a Philco 570 grandfather clock/radio combo, and my set suffers from the ubiquitous missing finial. I see there was a gentleman making repros some time back, but apparently no longer does so.
Anybody have a source for such an item? If not, does anybody know of a good high-resolution picture of one that I could bring to a wood worker to have them try to turn one for me?
Thanks!
I'd drop Steve Davis a note maybe he can help you out.
GLOM
Terry N3GTE
Seems I recall someone selling those en eBay but that's been a year or so ago.
Tim
I'm sorry, I cant help with this one.
M R Radios   C M Tubes
I took pictures of the one I have.  Sorry about the plastic.  It's a pain to mount and take off.  If this doesn't do it for you, let me know... I'll do one better.
