Seeking Woodworking Advice
If you next step is to reveneer the entire top anyway, I'd give the bleach a try. Even if it just turns into a learning experience you still gain something. Good Luck!
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4724 online users. [Complete List]
» 1 Member(s) | 4723 Guest(s)
