Two antenna leads?
Hi, I have a Wards 62-319 that has two antenna leads, a #1 and a #2, as well as a black ground. The radio is Broadcast, Middle Wave and Short Wave. The #1 antenna receives great on Broadcast, the #2 lesser so. What is the purpose of that second antenna lead? One piece of documentation says when using the #1 lead twist the #2 lead together with the ground. When I do this there is a slight improvement in reception.
Thanks, Alan
What you describe so far makes sense.
When using a dipole for SW (they probably had such a model of antenna)  it would have been connected to the two antenna leads.  But when using a single wire feed you would normally connect the antenna/black to ground.  Some radios (RCA for one) used a terminal strip with a link jumper to facilitate this.
Thanks so much for your reply. So this Airline radio either came with a dipole antenna, had one available as an accessory, or there were generic ones available. When using the dipole for the shortwave band (or possibly for either shortwave or broadcast?) the #1 and #2 leads were attached to it. Without the dipole the #1 lead is the long wire for both broadcast and shortwave and the #2 lead combines with the black ground wire to ground. Is this about right, or am I still messed up?
Alan
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4827 online users. [Complete List]
» 1 Member(s) | 4826 Guest(s)
