e- cap question
Working on re-capping an RCA 816k chassis, and someone in the past has replaced the e-caps with Mallory cans.
I have one that is a Mallory FP-214.
rated at 50 mfd and 50 mfd.
The voltage marking on the can is rubbed off.
The schematics don't specify voltage on the parts list.
Anyone know what the voltage should be on caps 53 and 54?
murf
Mruf, it is always nice to add a link to the schematic when asking questions such as yours.
Jerry
http://www.nostalgiaair.org/Resources/155/M0015155.htm
Murf
The two caps are listed as having 368 and 359V across them respectively.
This means they can experience close to 500V surge at cold startup.
I would use 500V rating.
Ok,
Thanks for the help.
murf
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4827 online users. [Complete List]
» 3 Member(s) | 4824 Guest(s)
