Philco 37-610T Bullet Restoration
Threads: 91
City: Jonesboro
State, Province, Country: AR
Here's the 1st video in the documenting of the restoration of the 37-610 chassis. This is the unboxing and inspection. I'll post updates and videos as I make progress, but I hope to have this one up and running in time for a Radio Show listening party on October 29th. An annual thing now, this being the 4th year.
Anyway, comments and questions are welcome.
[Video: https://youtu.be/PxBYmvqBPE4]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 91
City: Jonesboro
While working on the chassis, I came across a mod someone did in the past. The 6A8G tube socket has a 100ohm resister wired between pins 1-2, and a .5ufd cap going from pin 1 to chassis ground. Neither is in the parts list or the schematic, or in the "changes" paperwork documented by Philco. I'm guessing that at one point it was modded to accommodate a 6A8GT tube, am I correct? I plan to put a 6A8 tube back in there. So should I remove the added parts, or will leaving them in affect performance of the tube or circuit? By the way, according to the tube specs, Pin 1 of a 6A8 has no connection.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
It's been a couple weeks since my last post. Here's video 2 documenting the replacement of the film capacitors. Video 3 coming up shortly!
[Video: https://youtu.be/VN0c-bWqtCU]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 3 documenting the chassis restoration of my 37-610T "Bullet". Restuffing the bakelite block. It didn't go as smoothly as it usually does, but I documented it anyway.
[Video: https://youtu.be/5CrjyZYuiM0]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 4 of the chassis restoration. Part 1 of working on the electrolytics.
[Video: https://youtu.be/5MLmTcOK9v8]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 5 in the restoration series.
This is part 2 of changing the electrolytics.
[Video: https://youtu.be/3TofH__uLzM]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Video 6 in my series of restoring my Philco 37-610T "Bullet" radio. Towards the end, I make an unfortunate discovery.
[Video: https://youtu.be/dsJ35RpAYyc]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
Any philco w/a single 47,42, or 6F6 will work fine as a replacement.
Threads: 91
City: Jonesboro
Part 7 of the 37-610T chassis restoration. Swapping the speaker, and more of checking the coils.
[Video: https://youtu.be/0PwuYFA2nhU]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Part 8. Installing the power cord and repairing the dial lamp housing.
[Video: https://youtu.be/IYKNtrDqP3E]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Part 9 of the chassis restoration. Getting closer!
[Video: https://youtu.be/UmM2YTs4Uas]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Final chapter! (For now). Comments welcome. ![Icon_thumbup Icon_thumbup](https://philcoradio.com/phorum/images/smilies/icon_thumbup.gif) Thanks for following along. ![Icon_biggrin Icon_biggrin](https://philcoradio.com/phorum/images/smilies/icon_biggrin.gif) I hope something in these videos helps someone out in their own restoration. I'm far from an expert, but what little I know, has allowed me to restore 14 radios to working order in 3 years (with help from some nice folks along the way. Thank you!.)
[Video: https://youtu.be/1xZfBQUn5Ew]
Blessings,
Jeff W.
Jonesboro, Arkansas
1 - 0v - correct
2 - 0v - correct
3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM |
1 - 0v - correct
2 - 0v - correct
3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:13 PM |
I'm going to get back into it tonight. but I disconnected the 2 main resistors off this supply going to different parts ...TV MAN — 04:04 PM |
1 - 0v
2 - 0v
3 - 0v
4 - 12v
5 - 0v
6 - 11.9v
7 - 12v
8 - 12v
9 - 12v...R3Sons — 02:09 PM |
What is "everything else?"
