Philco 71b ??
It's my impression that it'd be easier to procure a new chassis or a whole radio.
Es mi imprecion de que seria mas facil de adquirir un nuevo chassis o un toda radio.
Hello Terry. I could send a photo of your chassis to see the pieces that tells me. Greetings.
Of course!!!
Check your PM box.
Hello I would need if some fellow has like the wires connected under the chassis of a philco 71b. Greetings.
Restoring Philco 96
There are currently 7474 online users. [Complete List]
» 3 Member(s) | 7471 Guest(s)
