New here. Thoughts on this 38-116 please.
(12-14-2016, 08:48 PM)Kenneth F. Besso Jr. Wrote:  show thee ,,under side,,,soo,we can tell you if caps,,resistors have been changed
So here's a pic of the underside:
Obviously some of the caps were replaced and some were not. Wondering why the prior restorer decided to leave the paper-in-wax ones in.
Just radio's ( in Canada) for capacitors and resistors,,Ron---is working on one of these,,look at the site (phorum list),, on how he has taken this radio apart,,,,to get to certain Capacitors,,,,,this is a little TIME consuming job--I KNOW someone else will Chime in here,,,----CHEERS
Mr.Ron's doing 37-640,,,kinda the same,,,will get you going,,,I hope
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
