Philco Cabinet ID
Can anyone ID this Cabinet. I believe its a Philco but not sure whats it for...
Looks brand new. A little dusty.. No markings on it ...
[Image: http://i292.photobucket.com/albums/mm38/...aym7wh.jpg]
Thanks
Skip...
I think it is akin to 49-500.
http://www.philcoradio.com/gallery/1949.htm#c
http://www.ebay.com/itm/Vintage-1949-Phi...SwZQRYf~Od
And here's a chassis for it, though a bit expensive:
http://www.ebay.com/itm/Philco-Transiton...Swo4pYf9C7
46-200I
Mike and Terry are correct; and in addition, it could be any of the following:
42-PT92, 46-200-I, 48-200-I, 49-500-I.
Ok thanks I will have to look around for a Chassis that will fit.
This is at the (pickers house) that I took the guys to....
Skip...
Ooooh, Nice!
 Did you buy it?
I have a 48-200 with a broken cabinet if you wanna sell it.
If you dont want to sell it then I have a chassis for it, Icon_lol
The chassis is ratty though..
Icon_smile
Looks like your case still has the aerial in it.
All, I just looked at this chassis we think is a fit for the Cabinet.. But no model numbers on it. Also all tubes are gone.. Can anyone maybe ID it???
[Image: http://i292.photobucket.com/albums/mm38/...tdi75t.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...92ia8w.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...xyqal6.jpg]
Thanks
Skip...
42-PT-92 if it has rubber-covered wiring; otherwise 46-200-I.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2710 online users. [Complete List]
» 2 Member(s) | 2708 Guest(s)
