Philco 38-116 Code 121
Hi Folks -
Didn't hear from anyone on model for the back so I went ahead and created one.  I'll attach it to this post if it can be of use to others. I plan to print it out using the tiled printing option and then tracing the vent locations on some tempered hardboard. I would love to have a the wording on a water slide decal to apply, but don't thing I can find one that would be almost 2' square - so I am checking on a a decal like the kind on storefront windows. -- Andy
Andy Sorrell
Palmyra, Virginia
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6403 online users. [Complete List]
» 3 Member(s) | 6400 Guest(s)
