I picked up one of these table top radios last weekend, heavy sucker. Anyway, does anyone have any knowledge of these and what, if any, pitfalls to watch out for when restoring one of these.
Had one back in the '70's when I was a teenager. Do remember it used a FM-1000 tube for the FM detector and it is a big table top set.
Here are some notes I generated when I worked on mine. http://home.ptd.net/~coraor/documents/48...nNotes.pdf
Excellent notes Bob, thank you.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
