Philco 49-1405
Won one of these on ebay.
http://cgi.ebay.com/0359914169
Was wondering if any of you have one and restored one? Thought the two arms was cool. Any known problems I should be aware of with this model? My first philco with a record changer.
thanks
Chris
Just the usual suspects...paper and electrolytic capacitors...the phono cartridges are probably bad - see Syl's how-to on rebuilding these here on the Phorum. Icon_smile
There are currently 8718 online users. [Complete List]
» 2 Member(s) | 8716 Guest(s)
