Thank you Ron Ramirez
I just joined this forum because I am starting to rebuild my first Philco model 46-1201 code 121. I also have a code 127 but that is not in as nice a shape as the 121. I am involved in several other vintage phongraph forums and have restored or rebuilt around six so far and repaired many others, but I needed info specific to this model and code and sure enough it was here that I found it. So, again... Thank you Ron Ramirez.
Microtouch
Well...I appreciate the kind words...thank you for joining, and for participating. Icon_smile
There are currently 10531 online users. [Complete List]
» 2 Member(s) | 10529 Guest(s)
