Model number for Freshman mini tombstone
Threads: 242
City: West Bend, Wisconsin
Threads: 415
City: Boston
Cool tubes very unique, nice set.
Not seen one of those.
Threads: 268
2X 35, 47, and 80??
Threads: 242
I know the globe tube is an 80 but will have to pull the other 3 out tomorrow night and look what they are.
Threads: 54
The chassis, and possibly the whole set, was manufactured by Ozarka Radio (or Belmont), according to the green plate, but they don't give the model number. The extra control above the dial does not belong there so ignore that in your search. Freshman didn't have anything to do with this set, obviously someone bought the rights to use the Freshman name, or the escutcheon came off of a later model Freshman set made after they merged with Freed-Eisemann, those sets were built in a plant in New Jersey, not Chicago which was where Ozarka was based.
(This post was last modified: 08-07-2017, 03:00 AM by Arran.)
Threads: 20
City: Orland Park
State, Province, Country: Illiinois
It's a Belmont, who mostly made sets for hardware stores, catalogs, Western Auto, department stores, Montgomery Ward, etc. Belmont used the Freshman name on a number of their radios, but I'm not sure who they were intended for, maybe catalog order or a long-gone department store chain. Wings-branded radios went to Goodyear tire shops, TrueTone went to Western Auto, Airline was Montgomery Ward (obviously).
Here's another Freshman-branded Belmont.
http://www.radiophile.com/belfm675.htm
Greg
Threads: 20
City: Orland Park
This is the only Belmont I could find with four tubes, one of them being an 80. Thoughts?
http://www.nostalgiaair.org/pagesbymodel...002053.pdf
Greg
Threads: 242
I think you came up with a winner, Greg. I just removed the tubes and, handily, the tube sockets have the tube numbers right on them. It does indeed have 80 , 47, 24, and 35/51 tubes. I agree with Arran that someone added what looks like a tone control above the escutcheon. This will, of course, be removed and the hole in the cabinet filled. Thanks to everyone for helping solve the mystery.
Threads: 54
Try looking under the Ozarka models as well as Belmont, the green plate has the stylized O-R logo as an Ozarka would have.
Threads: 20
City: Orland Park
The only 4-tube Ozarkas I could find were circa 1925-26, probably too old for this model. Of course, that doesn't mean there isn't one out there I didn't see.
Greg
Threads: 54
It's a simple enough set that you could probably use one of the schematics you found as a guide, if it hasn't been tampered with too much underneath.
Threads: 242
I'm finding the initial schematic that Greg found http://www.nostalgiaair.org/pagesbymodel...002053.pdf is the basic layout of this set. However what I thought was a tone control added appears to be a short wave band switch. There are several extra coils under the chassis that don't belong but look like they have been there for almost as long as the radio has been around. I'm torn between recapping / new resistors and trying it as is or trying to remove all of the short wave (or could be police band?) extras and wiring it per the sch linked to above.
Threads: 268
I would suspect that the extra coils are for the old police band, as you go higher in frequency w/a trf set the selectivity drops off. You don't really see very many trf sw sets most are regenerative or superhets. I have several Simplex sets that are very similar to yours electrically that are two band sets. The second band isn't calibrated or noted on the dial. These use a 58,57,47, and an 80. Simplex model N it's kinda strange in that there is an ac model that is a trf and a dc model that is a superhet.Perhaps a year or so new than your set.
http://www.nostalgiaair.org/pagesbymodel...043257.pdf
(This post was last modified: 08-11-2017, 09:24 PM by Radioroslyn.)
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
