Kolster K-20 A.F. Transformer
Hello, all.
Tried posting this on another site but didn't get any responses. Since I've always had good luck here, I thought I'd ask another newbie question: is anyone able to tell me what size A.F. transformers are used in a Kolster K-20? They are marked AFT1 and AFT2 on the schematic which can be found here:
http://www.nostalgiaair.org/pagesbymodel...040092.pdf
Thank you in advance for any help.
Dave
Perhaps a couple universal output transformers like the P-T291 from AES?
Hi Dave,
I'm not sure I understand what you are asking. Are you referring to physical size?? Or electrical equivalent??
Electrical equivalent
Ok What you are looking for are https://www.tubesandmore.com/products/tr...tage-10-ma  for both. If the transformers are enclosed and have a 1/2" core you can buy just the replacement winding.
Other then the generic AES transformer you could try an Edcor one, or try the solid state substitute circuit that was featured in the A.W.A Old Timer's Bulletin about ten years ago, I think it's posted online somewhere.
Thank you for the help.
Dave
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2108 online users. [Complete List]
» 1 Member(s) | 2107 Guest(s)
