New owner of 16b shouldered Tbone
Good call Mike - bass compensation it is! Great to learn all these subtle changes.
Ron - I was bewildered by the QAVC on our 16X, it seems a very lavish use (waste?) of an extra valve in the chassis! An RF amp is indeed a better use!
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2881 online users. [Complete List]
» 1 Member(s) | 2880 Guest(s)
