Philco 16B Tombstone Speaker P/N Question
I recently acquired a Philco 16B tombstone cabinet with speaker (no chassis), late version (rounded top).  The speaker does not have a part number stamped on it.  I have the early "flatter top" version and the P/N for the speaker is clearly stamped "H13".  Do all 16B tombstones use the same speaker?
Geoff, all 16B tombstones use the H-13 speaker.
M R Radios   C M Tubes
Thanks!
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3296 online users. [Complete List]
» 2 Member(s) | 3294 Guest(s)
