R-3 speaker
just came by R-3 speaker and need any information about it .
...such as?
Anything at all . I did not one existed until I bought this one . Thanks
nks
OK... Icon_smile
It was introduced with the rest of Philco's lineup for the 1932 selling season.
It was intended to connect to the output of a Philco radio of the time.
I have never seen any documentation on this unit other than mentions in 1932 Philco sales literature. I have never seen any other documentation on this speaker.
Thank you .
The speaker table error?
Philco 70 antenna lead
