speaker question.
Does anyone know if the speaker from a 70 and 71 are the same? I am strictly talking about cathedrals.
Thanks.
If it glows in the dark and heats up the house its MY kind of radio!  Icon_crazy
The 20,70,and 90 used several alliterations of the K speaker (sometimes called a pie pan speaker). It sports a painted brown or coated gray basket. The 71 uses a later K speaker that should work but ascetically is different. The 71 speaker may be hardwired in without a 4 pin plug. Ron would know better than I.
Early https://www.worthpoint.com/worthopedia/s...-132420086
Later https://antiqueradio.org/philc08.htm
Nope, the 71B used a K-7 speaker which has an 1125 ohm field coil. 20, 70 and 90 cathedral speakers all have 3100 ohm field coils.
more info here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Scroll down to, and download speakers.zip which was made in and intended for Microsoft Excel but also works in LibreOffice Calc and OpenOffice Calc.
thanks guys that answers it...
The speaker table error?
Philco 70 antenna lead
