Plastic covers for buttons on 48-482
Back in 2013 someone was inquiring about the clear plastic covers for the buttons on a Philco 48-482. It was mentioned that someone named David with Antique Radio Collectors could offer them.
I have been looking for sometime for my 48-482 to no avail. A year or so back I tried contacting this person mentioned but never received a reply nor could I find an Antique Radio Collectors.
Does anyone know if these are available anywhere. I tried checking RadioDaze, but it doesn't seem they make them either.
Thanks in advance for pointing me in a direction that might help.
Jim
That would be David Frush. Scroll down the page at this link for his email and other vendors of knobs.
http://philcoradio.com/phorum/showthread.php?tid=14950
Don't know if he is still in business or not.
There are currently 10139 online users. [Complete List]
» 2 Member(s) | 10137 Guest(s)
