06-25-2018, 07:58 PM
Thanks
Mark
39-6 Can Capacitor Question
Thanks Mark
06-25-2018, 08:44 PM
It is possible that the can is not the original and the values on the can and in it are the closest that the repair person could find. A little extra capacitance often will help this kind of circuit rather rthan hurt it, as long as you don't go too far.
06-25-2018, 09:21 PM
That was my original thought, but when I checked my sheets from Chuck Swark, the can was original. I can trace where they belong underneath the chassis but this was not matched correctly in previous repairs, so I want to make sure I don't miss anything.
Thanks.
06-25-2018, 10:52 PM
Looks like the original part was 30-2327. That one you have has a Philco part no. It might be a replacement or the factory could have subed it. Note the polarity.
06-26-2018, 09:54 AM
8uF should work in place of 12uF, will result in a bit lower B+ voltage.
06-26-2018, 10:31 AM
06-26-2018, 08:02 PM
Thanks all! The issue comes from the production change section of my schematic package where it says the original run of can 25 (30-2327) was replaced by 30-2179 ( mine) in runs 1-3 . It states that the only difference in the two was in the mounting. Clearly my can shows a dramatic schematic shift from what I'm looking at. I was hoping those of you who have repaired this model could let me know what you saw in can #25, otherwise I'll go directly off the specs and ignore the stamp.
Thanks for the input!
06-26-2018, 10:07 PM
Well,, from looking at the can and the schematic,,,,the can is reverse of the drawing,,, Yellow is feeding both sides of the can,,the 4uf which goes to the center tap of the transformer,,and the 8uf is going to the Chassis (Ground)----Schematic shows 4uf going to the Chassis,,,and the 12uf going to the center tap of the transformer,,,,cut the can open and restuff with thee right caps for the schematic,,,,,and REMARK CAN
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
