Philco 60B and 60L band switch question
(09-09-2018, 08:11 PM)klondike98 Wrote:  ...the link to Ron's post leads to photobucket pics that are no longer there...perhaps you could add them into this thread Ron?
Salute
[Image: http://philcoradio.com/images/phorum/Pho...t_coil.jpg]
[Image: http://philcoradio.com/images/phorum/Pho...pinout.jpg]
The photos have also been corrected in the link in question, and no longer link to Photobucket.
Wow!  Thanks Ron!
 I figured out the connections, but good to see someone has done this.  Makes it a bit easier for certain!
Regards,
Brian
The speaker table error?
Philco 70 antenna lead
There are currently 7095 online users. [Complete List]
» 1 Member(s) | 7094 Guest(s)
