Radiola Lamp Hood Replacement
I had not gotten quite done with the chemicals and electricity  - Igor - - Igor, throw the switch!
https://www.russoldradios.com/blog
Russ
russ
looks pretty good  Icon_thumbup
you going to start making them
sam
No. There are things that I would rather do for minimum wage.
A.E S used to sell reproduction Radiola 17 and 18 lamp hoods, at least they did in my 1994 catalog, I don't know who was reproducing them for them, or how many they made, or what happened to their stock, but after A.E.S went into the business of selling guitar and guitar amp resto parts the hood lamps, like many other items they offered, slowly disappeared. I have no doubt that the originals were stamped out with a set of dies and a press, maybe the repro ones were as well, if so what happened to the dies?
There are currently 10251 online users. [Complete List]
» 1 Member(s) | 10250 Guest(s)
