Does anyone out there heard of an "FETNA " radio? I picked up 9 radios at a rummage sale [as if I need anymore!] it's about mid 30's AC-DC with ballas tube, and a short wave band, BILL
AETNA perhaps? A pretty common off-brand, many made by Simplex and the Chicago independents.
Your right it is a "AETNA" the "A" and "E" are joined together and looked to me a "FE" THANKS now I can look up some information on it, BILL
