Unknown Chassis - Found!!
Customer sent this to me and claimed it was a 41-260, but it is not. Cannot even read most of the tubes. Can someone ID it?
Thank you,
How about a 41-255T  or possibly a 41-256T.
update: NOPE...I think its a 41-250T....only 8 tubes.
Bob,
Thx, but wrong tube layout.
I'm voting for 41-280 But there where a number of set that are vary similar from 40-42. Going from right to left tubes are XXL, XXL, 7B7, 7B7, 7C6, 41, 41, 84.
Regardless of actual model..............looks to be a job! How does it look underneath?
Will take some hours at that one.
Good luck. Icon_smile Icon_smile
Terry found it! It is a 41-280.
Thank you,
Paul, Clean underneath
The speaker table error?
Philco 70 antenna lead
There are currently 6875 online users. [Complete List]
» 2 Member(s) | 6873 Guest(s)
